Routing Question
The goal is to run 2 amps with their effects loops.
Amps: Mesa Mark v:25 | Mesa mini recto
PBC:
Guitar input > Loop 7-10 > out A| out B front of the amps
Effects loop Amp 1 send into>In1-4>Out 1-4 > Amp 1 return
Effects loop Amp 2 send into> In Loop 5-6>Out 5-6> Amp 2 return
Do you see any problem with this?
I've seen other solution that required purchasing Additional switching device but in theory the above route could work?
That should work, however you may need an isolation transformer to fix a ground loop.
