Select default button for button groups
Discussion in 'GT General Discussion' started by Jason Harrelson, Aug 13, 2019.
  1. Jason Harrelson
    Jason Harrelson
    Aug 7, 2019
    12
    0
    Is there a way to specify a button within a button group that is on by default when the Mastermind GT starts up?
    I have tried changing the order in which I add buttons to the group and the order of the buttons on the board layout and it still seems to default to the same button no matter what I try.
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,044
    1,091
    Probably the best way to do it is to use a Set IA action.
    Edit the button that you want to turn on and set its IA ID to a number other than 0 (1 is fine if you haven't used IA IDs anywhere else).
    In the Macros tab, edit the first macro that's not already being used (#0 if you haven't used any). Name it Startup or whatever you like. In the action list below, add this action:
    System / Set IA ID;1 off:None on:127
    Then, in Globals, set Startup Macro to 0
    When the GT starts up, it will run macro #0, and turn on the button you specified.
  3. Jason Harrelson
    Jason Harrelson
    Aug 7, 2019
    12
    0
Share This Page
