Hi Ron,
Thank you for you reply.
I watched your last IA button video but my problem still remain..
This is the right file, but I might have not explained my problem clearly enough - I am sorry for my poor English.
And I made a few correction in regards to the "send on preset change" and "update on preset change" after watching the video.
In case : I linked the last edited version of my file below.
There is no momentary buttons with a Set IA action. the momentary button I am referring to (on page 1) is the target of other buttons on page 7 (not momentary) that all have a Set IA off:0 on:1 targeting this momentary button on page 1.
I am never changing mastermind presets during in what is described below.
The idea is to have page 1 being an "access page" to 5 other pages opened by 5 different momentary buttons on page 1 ("Comp", "Pre-boost", "Delays", "Reverb" and "EQ") each of them corresponding to a different device. And each of those 5 pages filled with device-based presets (not mastermind presets) called via midi PC actions. Whenever I go on a device page and pick up a device based preset, I would like that when I go back to page 1, the light corresponding to this device's button would be ON, showing me that a "device preset" is currently active on this device. And if I go back to the device page and turn OFF the button corresponding to this device preset, then it turns the light OFF to the corresponding button on page 1
Now this works fine for all the devices that are in one of the PBC loops. I managed to do it by turning IA link ON to those 5 buttons on page 1 (which are momentary), with first action being "Audio / loop #x off: None on : None". This makes this button work as described above with its light ON or OFF according to whether this device's loop is ON or OFF. (I turn the device loop ON or OFF when switching ON or OFF a button on this device page)
Nevertheless - and that's where the problem resides - I have to find a different way for the H9 which is located after the PBC output (so the IA link ON and with first action being "Audio / loop ..." won't work)
I thought of doing it via midi commands only : On the H9 page, (page 7 called Delays on my file) on each button I have basically one midi command (CC#15) that toggles between H9 being bypass and active and another one that sends the PC number.
But I'm having trouble getting the button on page 1 work accordingly ..
On that page 1 button, Instead of having an IA link ON and with first action "Audio / Loop ... ", I tried having IA link ON with first action being "H9 / CC Toggle #15 off : None on : None" , but the button is always OFF when I come back to page 1. Thats why I tried to put set IA actions on page 7 buttons, that would turn ON/OFF this button on page 1. But here again (and as said in my first post) it only works when I come back to page 1 and when I switch to other pages and back, the button is OFF (whereas other momentary buttons on page 1 having the IA link ON with first action "Audio / loop #x off: None on : None" work fine when I go around all pages and come back to page 1 : Still ON if the device's loop is ON, and OFF otherwise.
I am sorry for the long post.
It's been like a month that I received the PBC and came on this forum on a regular basis. I can see how you take the time to reply to people's questions. I have been surprised that people are mostly answered by the product's designer himself, and felt greatly thankful for this. Don't worry If you don't have time to go through my problem, I totally understand and I am sure that with time, trials and errors I'll find a way to do it
Again thank you.
Pierre M.
