Chris@KatsuKuriMedia
I'm setting an IA to be a Hold type. My original function of the button (with or without the Hold option) is a momentary IA (using it for Loop 1 switch function on Infinity Looper).
IA works great as a normal button. And when I turn on the HOLD function and assign actions, the HOLD function works as intended and can be momentary, which i need.
However, the ORIGINAL function of the button that used to work no problem now seems to not work on a normal press. If I press the button quickly several times to get the main function, it eventually works, but a normal press doesn't seem to do it.
Is this a known issue?
My rjs file is attached. Buttons in question are Page 1 bottom right, Loop1 and Loop2.
