fusionpete
Hello
Can someone advise what I need to do to get my expression pedal to work from the PBC 6x.
I’m using a Boss EV-30 to control 4 midi pedals, mainly an H9 which I’m using for wah. I also have the Mobius, Volante and Jet reverb.
The pedal works fine when connected directly to the H9, so I know it works, but I also want to use it to control other parameters on the rest of my midi pedals. Each pedal is set to its own midi channel, so no conflicting information.
Would it be a better idea to assign using the Exp Pedal 1 to 4, with each setting assigned to each pedal (assuming I want to control one pedal in isolation).
I could also use some of the other settings for pairs of pedals, should that need arise as the editing page allows for 2 pedals..
For the H9, my coding is - H9: Exp Pedal / CC Toggle #17 off:0 on:127 - Is this correct. If so, it’s not working.
Thanks
Thanks
