I will try that immediately and get back...The pedals in the loop should have no effect if the loops are off. Have you tried turning off all of the buffers? If a buffer or click stopper has failed, it could have that effect.
Just tested all buffers Off, no change. For what its worth, going directly into the amp I have to turn my instrument volume down to 6/10 to get the same... this is basically a new unit. running latest firmware. I am starting to think this may be awarranty callI will try that immediately and get back...
Issue is in last section. Problem occurs when goin in 1/10 and out A none of the other sectionsTry each group of loops: In 1-4 to Out 1-4, In 5-6 to Out 5-6 and In 7-10 to Out A. See which section is where the problem lies. That will help us debug it.
Also, are you trying to use any stereo effects? And, how do you have the mono/stereo buttons set on the rear?
Currently, on Preset one, If I have the no 10 loop in parallel with the Flint in it, I get a weak signal weather the loop is on or off, If I set the loop to series, I still get weak signal in or out ( loop ) On other preset positions, If button set to stereo, I get good signal when loop off, silence when loop on. button set to mono, I get good signal loop in or outIssue somehow related to the Flint it seems. But something about preset 1. I am attaching the setup file, maybe you can locate something in preset 1. But there was the same issue in all presets, unless I change the mono / stereo button to mono ( pushed in ) then it goes away...except for preset 1. If I want to use the PCB as an ABY using stereo effects when both outs are on, can I not use stereo ?
O.K. my bad for not doing all my home work. Sorry about that. BUt, tha does not explain ( unless I am missing something ) whay ONe preset behaves differently ????Please read the post at the top of the forum "Using Stereo Effects" - when using a mono input / stereo output pedal, you have to use a ring disconnect cable to go from the loop send to the pedal input, otherwise you will have volume loss. This is a cable with a TS plug on one side and a TRS plug on the other, with the ring disconnected on the TRS side. Details are in my link.
no, I only have 3 presets that I started putting toghether, that all use the flint I did not get very far because of this issue and other constraints. But I uploaded the setup file a couple responses back, if you want to look at it, maybe something will be obvious to you ?I don't know... what settings are different in preset 1? Is that the only preset that has the Flint's loop enabled?
