Kamil Rustam
Hello, so here are the issues (Hopefully you have a solution..):
1- I programmed one of the ext buttons to send midi tap to my Strymon Mobius and that works fine but I would like, when I select that preset, to have the LED always on (To remind me it is an active button for that preset ) Whatever I do in the "Button Settings" Page On & Off Colors ( I tried black on both on & Off/ Red on Both on & Off, etc...), the preset starts with a non lit led and each time I press the switch it switches from on to Off .
2- I have the other ext button programmed to be a master Tap Tempo and iy works great as well but is there a possibility to have it flash the tempo as soon as I select the preset ? right now it will only flash after I press the switch
3- ( A more problematic thing...) On another preset I programmed one of the ext buttons to send a fn switch so I can trigger my modified super ego. It works but I noticed a slight level change in my sound when the relay triggers, so, to test and see if the culprit was one of the other fx, I created a preset with no FX loop on ( Straight guitar signal through the PBC) and I even disconnected the Fn Switch from the PBC, and when I press the ext buttons (sending the signal to the fn switch, I still get a slight level change for a millisecond... it seems like that shouldn't be happening?
Any suggestions
Thanks
Any suggestions
Thanks
