[Solved] Having one IA turn off another
Rick
I am using IAs to turn on/off scenes on my Axe FX III. I have 4 Has set up for Scenes 1-4 as follows:
Scene 1: CC 118, On 0, Off 0 (all scenes are set to return to Scene 1 on Off)
Scene 2: CC 118, On 1, Off 0
Scene 3: CC 118, On 2, Off 0
Scene 4: CC 118, On 3, Off 0
All scenes work as they should. My problem is that if I go to scene 2, then directly to scene 3 the scene 2 IA remains lit in "On" mode. If I step on it to turn it off, it sends the command to go back to scene 1.
Soooooo... Is there a way to set the MMGT up where stepping on 1 button return another to off mode without sending a value? I hope I am explaining that right. What I want is 4 buttons for scenes 1-4, and selecting any one resets the rest to off mode.
I'm sure I am overlooking something simple, but I haven't sorted this one yet.
Set the "Group" parameter on each button to the same number. Pressing one button in a group will turn off all the other buttons in the same group. There are group parameters in global settings that allow you to fine tune the group. For your purposes. I recommend setting "Allow all buttons off" to ON and "Send off messages" to OFF for your scene button group.
Ron, setting the button to a group does get them to do what I needed.
EDIT: I found the setting I was looking for in Edit Groups. Thanks!
