dkbarnwell
Hey,
Apparently Marshall Amps has pulled a fast one on me... I have two #2466 Vintage Modern heads and one JCM #2555 head. The Amp Gizmo switches the JCM perfectly! Hit the button and the channel switches, hit the button again, channel switches back. The same cannot be said for the #2466 VMs. Push the button, channels changes, push the button again, channels doesn't change, push the button again, channel changes. so you see the problem I have, if I program a MIDI preset to switch the channels the two amps will be out of sync on the next preset. It appears that one setup is momentary and one is latching...what do I do here???
The footswitch for the VM's simply toggles the channels back and forth. It would seem that I have a mixed bag of schemes (thanks Marshall).
Any suggestions?
Thanks in advance,
Derek
Any suggestions?
Thanks in advance,
Derek
