Split insert loop audio path position affects stereo output on PBC 6/X (for Ron)
mcvittym
I have split the insert loop. When I put insert 2 in the position I want it to be (before loops 4, 5 and 6, which are set for stereo) the output from the PBC is in mono, rather what it should be, ie in stereo. When I put insert 2 after loop 6, the output from the PBC is in stereo, what it should be. I attach a screen dump of my master audio settings and images of the PBC control panel showing each of the two settings for insert loop 2. This doesn't seem right.
The outputs from the PBC are connected to Walrus Audio Canvas Stereo and then to Focusrite Scarlett 2i2. I'm listening via the headphone monitor output.
Any suggestions, Ron?
I've raised a support ticket as well.
Problem solved - the stereo/mono switch on my Strymon Cloudburst was switched to mono. I switched it back to stereo and it's all working.
