Stereo Rig Loop 7 Must be on for dry signal to pass
Mikeohman
I have been running with a single amp and added a second amp today.
Loop 7 Mobius - Loop 8 Timeline - Loop 9 Big Sky - Loop 10 H9
Mastermind Switches: Mono signal into In 7-10, stereo output – Mono -> Stereo OUT, Mono Output OUT
Loop 7 must be turned on for the dry signal to pass through to the second amp.
TRS to dual TS cables for the inputs solved the problem
Yes, when running effects in parallel, you will need special cabling for pedal inputs, even if the pedal has a mono input. Otherwise, the mono inputs will interfere with the stereo signal that's fed to the other pedals.
I wrote a post with lots of details about this topic:
USING STEREO EFFECTS
Excellent post re" Using Stereo Effects. Thanks. My system is working almost perfectly. The only thing not working is a global function switch issue. I was using the boost feature on my amp and had a global button on Button 6 that activated the relay and worked perfectly.
I am now going to use a pedal that is in loop 4 as the boost, but I cannot yet get the previous global button to turn off.
No matter what I do (so far anyway), it reverts back to a global button.
Presets page works perfectly but on page 2 (stomp box / loops on off) the Global check box refuses to stay un-checked. Toggling any field on this page also turns on the Global check box. Software issue? File attached.
  • Mike Ohman Global Button issue.rjs
I see what's happening now - the checkbox is staying checked, but it doesn't actually make the button global or have any other effects, correct?
Yes and a bit more. The button will uncheck, but then rechecks itself. Therefore I cannot access loop 6, nor can I re-program the RJM button 6 (presets page) to do what I want it to do.
Some further detail / clarification. I used to have button 6 globally switch my amp boost circuit on and off - that function HAS CHANGED - it NO Longer works that way which is correct.
Now I want to use button 6 globally as a boost - turning on and off Loop 6 but I cannot access loop 6...
Were you able to fix this bug in the 4.0 release?
