spikeymcspikeface
It's possibly me being daft, but I've tried everything I can think of, and I can't get what feels like it ought to be a really simple thing to work ...
All I want to do is have the ability to toggle the bypass on / off for Insert #1 of my H90. FYI it's a Noise Gate (sitting in H90's Insert #1), so I want the default for it to be on in relevant Presets (ie. generally higher gain patches), with the option to bypass it when I need to (eg. sometimes, gates being what they are, it kills the sustain earlier than I'd want).
So, I've set up the External Control in the H90 editor so cc10 toggles Insert #1 Active / Bypass. In the MMGT editor I've added an IA button to relevant Presets, which sends a momentary 0 / 127 to H90 via cc10. It works successfully to toggle Insert #1 on / off. So far so good. But ...
If I switch between two Programs that have this IA button, the state of the Active / Bypass won't change. Eg. I select Preset 1, use the IA to bypass Insert #1 on the H90; then select Preset 2, but instead of defaulting to active, the Insert #1 state remains bypassed.
I've tried all sorts of combinations of 'Send on Preset Change' / 'Update on Preset Change' / 'Only On Messages' / etc, but nothing seems to allow me to fix the default for each Preset to Insert #1 active.
Any ideas what am doing wrong ?!?
Thanks one & all.
Thanks one & all.
