Hi. I just noticed that if I change the "Type" on any Strymon pedal and reload the preset on Mastermind, the Strymon will not reload the preset. So for example, if the Strymon preset is using dtape type and I move the dial to Digital and then reload the preset with Mastermind,the Strymon pedal will not go back and reload the actual preset --- dtape. Basically if I make any changes to the strymon pedal within the same preset, reloading on mastermind will not effect the strymon except the bypass state. If I change presets on the strymon pedal manually then use mastermind to reload the preset it will go back fine.
I have "send redundant PCs" on (pedals will not switch without it) and tried direct send CC/PC setting. The only boxes not checked on device screen are the "Ignore" ones.
Any thoughts???
Any thoughts???
