Strymon volante looper midi question
Discussion in 'PBC General Discussion' started by Michael Grossman, Jan 12, 2020.
  1. Michael Grossman
    Michael Grossman
    Jan 27, 2018
    7
    0
    Anyone know if the Volante sos looper is midi compatible and if so how to program the pbc mastermind to.use it?
  2. ataglianetti
    ataglianetti
    Dec 27, 2019
    21
    2
    It is MIDI compatible. There are CC's to enter SOS mode and CC's for each footswitch.
  3. Michael Grossman
    Michael Grossman
    Jan 27, 2018
    7
    0
    I'd appreciate any advice on how to program buttons to accomplish this. If I set aside a whole button page devoted to this, for example, I'd need one button to enter sos mode, one button for telling tap button to stop and start recording (or separate buttons for each. A button or two for pause functions, a button for reverse and a button for infinitive repeat.
    Any help would be appreciated. I've managed to utilize the pbc without dealing with cc messages thus far and I guess my time is up.
  4. Michael Grossman
    Michael Grossman
    Jan 27, 2018
    7
    0
    If I assign a button and send cc number 41 that should direct volante to enter sos mode, correct? Is there another cc message number to begin recording and one to stop recording/start playback? Confused. Strymon Manual says value for on for cc message 41 is range of 1-127, what does that mean?
  5. Michael Grossman
    Michael Grossman
    Jan 27, 2018
    7
    0
    I guess you could assign a button to send cc message 82 for footswitch tap to value 127 "press," so everytime you use that button it will send a message to engage the tap footswitch on volante?
  6. rjmmusic
    Staff Member
    Jan 18, 2010
    6,057
    1,093
    I've never used a Volante, but what they mean there is that a value of 0 means off and a value of 1 through 127 means on. Just use off:0 on:127 and it'll work fine.
    I don't see any sepcific record / play CCs, so I'm guessing you'll need to use the CCs for "On SW" "Fav SW" and "Tap SW" - these correspond to the three buttons on the Volante. Pressing one of them on the PBC should act like pressing them on the Volante itself. Turn on SOS using that CC, then assign buttons for the On, Fav and Tap buttons and see if they operate the looper.
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    6,057
    1,093
    There's a Tap Tempo CC and a Tap SW (Switch) CC available. I'm not sure what the difference is, except that I would expect that the Tap Tempo CC will always function as tap tempo, but the Tap SW CC will operate differently based on mode (If the looper is active, it will control the looper instead)
  8. ataglianetti
    ataglianetti
    Dec 27, 2019
    21
    2
    You have to simulate the switch press down / up. Once you're in SOS mode, the On/Off, Favorite, and Tap switches are used for controlling the SOS loop functions.
    CC 82 for the Tap switch: 127 for press, 0 for release.
    CC 81 for the Favorite switch: 127 for press, 0 for release.
    CC 80 for the On/Off switch: 127 for press, 0 for release.
    I think you'll need to use a CC momentary message so the switch executes 127 on press, 0 on release. It's definitely working for me on a PBC 6X and a Volante.
  9. Michael Grossman
    Michael Grossman
    Jan 27, 2018
    7
    0
    Thank you guys. I figured it out and you were all very gracious to help out. Sorry I wasnt back to say thanks sooner!
Share This Page
