Suggestions with rig setup - Need ideas Ron.
autumn09
Hi fellow RJM users. Need some ideas with a setup.
I want to go with a W/D setup and run with the following gear. I basically after suggestions or even better diagram with basic fundemental arranagement of setup with running x2 RG16s into two seperate amps.
I have:
- x2 Marshall 30th Anniversary Heads
- x2 Orange 4x12 Cabs
- x2 RG-16s
- x1 Mini Line Mixer
- x1 PCM 70
- x1 Line 6 Echo Pro
- x1 TC G Major2
- x1 Hush eliminator
- x1 Axes Electronics Buffer (I love this buffer)
- + Pedals= x2 Klons, x1 Timmy, 1xZendrive, 1xT-Rex Replica Delay, 1x Boiling Point Rock box, 1x Fulltone Tremelo.
Be a big help as well thanks :)
In brief:
- Run all the pedals in the first RG-16, run it through a Y cable to both amps (or use loop 8 to split: loop output to the dry amp, loop send to the wet amp)
- Put the second RG-16 in the wet amp's loop. Run the rack effects in parallel using an RG-16 and Mini Line Mixer (see the diagrams we have on the RG-16 page)
- Is the Hush stereo? If so, you can try to put in in the loop of both amps. It would be the only thing in the dry amp loop, and would go in the first loop of the RG-16 in the wet amp.
maybe you should think about the effect gizmo, because your amps can be controlled by midi - so you won´t need the switching unit of the RG-16.
with the effect gizmo you get 12 loops in 1 unit.
