Hi!
I am planning to control the Synergy System - http://synergyamps.com/shop/syn002 - via MIDI with the GT22.
In the SYN2 manual P10 these are the instructions to use a 3rd party MIDI controller.
http://synergyamps.com/support/send/2-manuals/13-syn-2
"Programming
To program the SYN2 to respond to your MIDI controller, do the following:
Before I buy the SYN2. Any experience to share using the GT22 controlling the SYN2 (if It works ok, issues, etc)?
Thanks in advance!
Xavier
"Programming
- Make sure your MIDI controller is connected to the SYN2’s MIDI input jack
- Select a preset on the MIDI controller
- Using the channel select button on the SYN2, select the module channel (or bypass) you wish to have come on when the preset is selected using the SYN-2 front panel SELECT pushbutton.
- Hold the channel select button until the bypass LED flashes. This should take about 3 seconds.
Thanks in advance!
Xavier
