Firmware 4.3 introduces a new action: System / Set IA. This allows one IA button to set the state of another. This should allow for some more complex configurations - I'll be interested to see what people come up with.
Each IA button now has an IA ID number, which can range from 0 to 255. An ID of 0 is the default, and is always ignored - Set IA will never affect a button that has an ID of 0. You can assign the same ID number to more than one IA button if you want.
The Set IA action looks like this:
System / Set IA IA:12 off:0 on:1
IA is the ID number - in this example, the action will affect all IA buttons with ID#12. Off value and on value are the desired button states. On a normal (non-cycle) IA button, 0 turns the button off and 1 turns the button on. On an IA cycle button, values 0 through 3 select steps 1 through 4 respectively.
You can set it up so that one button turns a second button, the second button turns on a third, etc. The only thing the system won't allow is loops (button A changes button B, then button B changes button A). A button can only be affected by a Set IA action once per preset change or IA button press. This prevents you from locking up the system.
Questions? Let me know!
