tap tempo axe3
Soren Kelly
Hi all
What am i doing wrong cant get the tap tempo to show me the tempo in numbers, it goes up and down without me tapping most of the time it goes to 251.0 and stays there..
cheers
  • tap tempo.rjs
I don't have an Axe-Fx III in front of me at the moment, but one problem I see is that MIDI Receive Channel is set to 1. It's probably not related to the tempo problem, but it will cause problems for sure. Set it to None and see if that helps, and if not, I'll check with an Axe-Fx as soon as I can.
Thanks...
another question is it possible to get the gt22 to follow the axe when i change a patch on the axe 3
Cheers
