jluparello
Okay. So maybe I'm trying to do too much here but it's just not working the way I would expect. I'm trying to use two methods to set the tempo in my TC Electronics Flashback X4 which, although limited, does accept midi clock. First, I have tempos set for each Song, midi clock enabled and Ignore Preset Tempos set. Second, and intended as a backup, I have a button configured for Tap Tempo - Flash w/ Tempo and Update State on Preset Change.
The Tap Tempo works perfectly and in fact, seems to be the only piece of the equation working. When I bank to a new song, the set tempo displays on the screen and the tap button flashes at the new tempo of the new song. But the new tempo doesn't update in the pedal. The only way to get the tempo updated in the pedal is to override the Song tempo and use the built in Tap Tempo button.
There are a few potential issues here... I'm only a few weeks into my relationship with the PBC so I don't know what I don't know AND the Flashback X4 has grossly limited midi capabilities. So much so that even the manual for it isn't even correct. It was released as omni midi but shortly thereafter a firmware release set it to channel 1 with no ability to override this. Regardless, I don't know if I'm trying to do too much, if I'm not quite doing something right OR if it's just a bug/limitation in TC's midi capabilities.
Any guidance would be appreciated!!
UPDATE: Removing the Tap Tempo button doesn't make a difference, other than not allowing me to "manually" bring the Flashback into rhythm. Now I'm wondering if the Ignore Preset Tempos isn't working as expected and I should change the presets from Same to Song or Off.
