Tap tempo
mcandy879
It used to work before, now I updated my settings list and my delays pedals tempo don't merge with RJM's tempo, I watched video about tempo but still can't find the issue. MIDI works fine, all MIDI pedals receive PC, CC fine, but not tempo
  • 3.1.rjs
Are the delay pedals connected directly to the PBC's MIDI output, or is there something in between? If there's something in between, try connecting the delays directly to see if one of those devices is filtering out clock messages.
Yes, I have. Tried different cabling and found the problem, apparently one pedal's MIDI wasn't set up correctly, now everything works. Thank you for help!
