Timing Settings: Do Not Repeat
Discussion in 'PBC General Discussion' started by ataglianetti, Jan 16, 2020.
  1. ataglianetti
    ataglianetti
    Dec 27, 2019
    21
    2
    Is it possible to adjust the timing settings so that a message is only sent once, without repeating if held?
    I'd like to have a single button that, when pressed, sends a Dev PC + message, but when held, sends a Dev PC - message.
    When holding the button to Dev PC -, the PBC keeps sending the Dev PC - message until the button is released. Is there any way to make it so the message does not repeat on a button hold?
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,057
    1,093
    Set the First Repeat parameter to a number that's higher than the Hold Time parameter. It'll trigger the hold function before it starts repeating.
  3. ataglianetti
    ataglianetti
    Dec 27, 2019
    21
    2
    Thanks Ron, works like a charm!
Share This Page
