The Stever
Please send me your settings file and I'll have a look.
First thing that comes to mind is a cable with a partial ground. Have you tried playing straight through the pedalboard with all pedals bypassed? If doing that fixes the issue, then check each pedal separately to see which is causing the issue, then move on to checking the send and return cables on the offending pedal. Replace the bad one and you should be good to go.Hello,
My PB is setup for stereo. For some reason The amplifier connected to the right output Jack on the PB is not playing at normal volume. I have to turn up the volume on the amp considerably to match the volume level of the left side amp.
The amp doesn’t sound the way it should .
It’s not nearly as loud and full with the volume turned up. It’s hard to describe.
When I plug my guitar directly into the right side amp it sounds normal - loud and full.
Do you have any idea what would cause this?
If you turn on Stereo Output, then it should show both outputs 1 and 2.I’ll try using one output from the rig.
why does the PBC6X manual show 2 Output designations on the display? Mine has always only shown 1 output.
