JeffMarshMusic
Hello again Ron,
For this particular pedalboard with my new PBC, I want to keep everything analog with the last digital reverb set to kill dry/parallel. I discovered this cool analog EQ with presets that's midi controllable.
http://www.freethetone.com/en/products/effects/pa1q.html
I've run out of loops in the PBC and want to wait before adding a Mini Effects Gizmo, so I'm thinking I can place this pedal before the loop 5/6 insert. But I'd need to enable/disable it via midi.
So... I'm trippin' on the fact that the device is not True Bypass, but has a buffer on all the time even when the effect is bypassed. I won't be using the effect all the time, so it bugs me that it would be in the signal path all the time. I would prefer it if it were True Bypass or in a loop, but I lack the education to justify the head trip (LOL). I really want this setup to sound analog, but I might be overthinking it and perceiving it as the A/D conversions I'm trying to avoid.
You sir, will know the reality I'm unable to see, so I'd love to know your take on it.
Thanks,
Jeff
P.S.
https://neunaber.net/blogs/neunaber-audio-blog/13827985-when-is-true-bypass-appropriate
Thanks,
Jeff
P.S.
