Is that a global change, or will i have to assign the mute switch to mute the outputs for every preset?The tuner mutes at the input, not at the output, so if you have some unusual routing, then signal could still make it through.
You could make the Mute button also control the outputs, add actions to the button like this:
Audio / Output A off:ON on:OFF
Audio / Output B off:ON on:OFF
That will turn off the outputs as well as the input.
Awesome. Thanks a lot.It only has to be done once. And I confirmed that mine DOES mute the outputs, but only because I added the extra step Ron talks about above.
