You can even control 2 different amps, both at the same time. I used to do this with a pair of Peavey heads, and use a couple of the audio loops to select between them. Seems a long time ago now!
both amps will end up being on the same channel using the Amp 1 Amp 2 outs on the RG-16. I use to do this bit if you want 1 amp on clean and one on lead or any combination you will need to use some of your effect loop spots like 5-8 or how ever many you would need for the peavy. Or get a Mini amp gizmo, run RG-16 to one amp and MAG to the other and your problems are solved
