UPDATE : PBC/6X WITH KEMPER PLAYER ?? BETA FIRMWARE FROM KEMPER SOLVED MY ISSUE .
PAPITO
Hello guys I'm new here !
Has Anyone tried the KEMPER PLAYER with a PBC 6X or 10 ? Will it work ? I am planning on having the Line6 Hx One , The Kemper player and pedals with the PBC/6X ?
no one ! Ok I might just purchased the wrong product , if no one will say anything ... I don't where else . I'll just request a return if I can't figure out on my own !
The Kemper Player doesn't have MIDI in and out, correct? If so, it's probably not going to work. There may be something you can do with a USB MIDI host adapter, but I don't know anyone who's tried that yet.
Thank you , well I had it worked with a dDPC-5 Gen3 from disaster area designs using midi over usb no midi adapter but was having a latency witch I see another midi controller manufacturer came up with a fix for . Regardless I will try it once I get my PBC/6x I wasn't home to sign for it due to having a Gig in Guadeloupe last night .
PLEASE HELP !! I am positive this pic 6x can work fine with the kemper I just need figure how to set it as generic device . if I let the pic on the default mini gizmo it works as if every preset goes from 1 and up , but I try to set it the way I think it should as the kpp has 50 rigs ( presets ) 10 banks I'm really struggling here lol
The Kemper has a non-standard numbering scheme, you'll have to work around it. If you're working in performance mode, presets 1-5 are the first rig, presets 6-10 are the second. You'll have to use this numbering to access it.
how would you suggest to configure this for the Kemper Player please ?
Have you tried just setting it up as a Profiler instead of Generic? That will probably work if you turn off Auto Names and Sync Names.
Thank you ! I try it and it seems to work better , but I still can't program a preset on the PBC to call just any desired rig on Kemper Player . it would just go to whatever that is set by default . that's the best way to explain what is actually happening .
Do you know if I can have workaround for when recall a preset on the Kemper Player from PBC for the kemper NOT go( let's say I want preset 1-4 ) to go 1-5 before it goes to 1-4 ?
I'm not sure what you mean. Can you describe this further?
And, please let me know how it's connected to the PBC. I'm curious, since the Kemper Player doesn't have a MIDI input.
OK I'm using usb to midi adapter that connects from the hx one to the kemper .
  • ST- PBC:6X KEMPER:HXONE.rjs
I know that the kpp receive messages from the the channels ( Omni ) what I noticed the problem begins when I start programming the footswitches . I would be more than happy to send you guys my Kemper Player if that would help an update to work with this device . although I know kemper they will come out with an update for that device as well . He said at NAMM it would take less than a month but that still didn't come out yet .
If the KPP is receiving in Omni mode, then that's the cause of the problem - it's responding to MIDI messages for every device. That needs to be fixed on the KPP - we can't do anything about it on our side.
