Using balanced TRS cables vs. TS unbalanced with the RG16.
DRC
I am going to finally purchase an RG16 (or Effects Gizmo) this Friday. Each loop will feed two mono delays (or a delay and a verb) that will be summed to mono by a line mixer. I am going to be using a y-cable (1/4" to dual XLR male) to feed my EFX units from each RG16 loop. I'm assuming that wiring up a balanced TRS jack and splitting it isn't going to be a problem but I just thought I'd ask.
Re: Using balanced TRS cables vs. TS unbalanced with the RG1
You're going to have to be very careful how that Y cable is built, but if you do it right, it'll work fine. The RG-16 output will be unbalanced, so the 1/4" end will need to be unbalanced, and the tip conductor will need to connect to both XLRs.
I just send my check to Sweetwater and I'll have an Effects Gizmo, an Amp Gizmo, a Mastermind here by the middle of May!!
Now I have to get this cable situation taken care of. I all ready have a few balanced XLR (F) to dual XLR (M) splits in my cable box. I am wondering if using a balanced TRS to XLR (M) will work just fine? I am pretty sure I have used balanced cable in a guitar rig before. Does the 1/4 jack coming from the Effects Gizmo have to be a TS jack or will a TRS jack work just fine? I also already have TRS to XLR (M) so it would save me some trouble. If it's a necessity, I will wire up some TS to XLR (M) with pin 2 hot but just keeping it balanced will save me some trouble.
What's the verdict?
Do you want the same signal to go to both XLRs? If so, you'll need to rewire the TRS to TS. Otherwise, one XLR will get signal, the other will get nothing.
I gotcha. So Pin 3 is gonna be pretty much useless all the way to the effects? I have been doing searches for the past 3 hours trying to figure out how to pull this off. I'll go TS to XLR (M) > XLR (F) to dual XLR (M) > to my T.C. and Lexicon units.
Thanks for the heads up.
