Using exp on PBC
Discussion in 'PBC General Discussion' started by P-air, Jul 20, 2019.
  1. P-air
    P-air
    May 10, 2019
    30
    1
    Hi,
    I need an extra ext switch, a 3rd one, can i use the Exp pedal on the PBC?
    regards,
    pierre
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    5,732
    1,006
    I've never tried it, but with the right wiring, it should work. The switch would have to be custom made, we don't make them. It would be limited - you couldn't have an LED on the switch, for example. You could simulate an IA button using the expression pedal switch actions, although it would not have all of the IA button features like groups, update on preset change, etc.
    To build it, a LATCHING switch would need to be connected between the ring and sleeve of the expression pedal jack, and a 10k resistor would need to be connected between the tip and ring of the expression pedal jack.
    (Edited 10/8 to correct switch type above)
    #2 rjmmusic, Jul 21, 2019
  3. P-air
    P-air
    May 10, 2019
    30
    1
    Would that switch be able to be a straight on-off for the boost on my amp?
  4. rjmmusic
    Staff Member
    Jan 18, 2010
    5,732
    1,006
    The switch will be able to do anything that the built in buttons can do.
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    5,732
    1,006
    Note that I edited the description above, you need a latching switch to do this - this is the only case you'd ever use a latching switch with the PBC.
Share This Page
