Using loopi foot switch for bank up and bank down on pbc 10
anico87
Want to use a loopi ext switch to control bank up and bank down.
It’s connected via trs from loopi to the pbc 10 ext switch jack.
how do I program it on the editor , can’t seem to figure it out.
As long as the switch is momentary, you should be ok. Go to the Buttons tab in the editor, right-click on the switch in the upper right corner - the one that's off by itself. In the menu that pops up, select Type > Bank Down. Repeat for the button in the lower right, this time selecting Type > Bank Up.
Perfect thanks for that, managed to get it to work.
this pedal has one led for each momentary switch, can’t get them
To turn on, I managed to get one to turn on yesterday from the button settings but now I can’t.
Just want to have the led always lit.
Thank you again.
If you edit the buttons in the editor and set both Off Color and On Color to something other than black, the LEDs should stay on all the time. (Assuming the switch is wired correctly).
