betweenus
Get Preset Names
The Get Preset Names process allows you to read preset names, and optionally scene names into the GT.
Once you've done the above steps, follow this process:
Once you've set your options, press Start. It will ask for confirmation, then start the process. If for some reason the process isn't running, check your MIDI connections and MIDI channel settings.
- Enter setup by holding the small black buttons under the screen for 3 seconds
- Select Edit Devices, then select the Axe-Fx III device
- Now press Get Preset Names
- You'll be presented with a menu. Start Preset and End Preset indicates the range of Axe-Fx presets that you want to read. Dest Preset is the first preset on the GT that will receive the preset names
- You can also turn on Get Scenes, which will read scene names in addition to preset names
- Create Songs changes the way presets and scenes are handled in the GT. This option is described in detail in the GT manual
The preset and scene names will be written to the presets as requested. Also, the GT presets will be programmed to recall the correct Axe-Fx preset numbers.
Question!
Why does my GT22 do not load the preset and scene namens with the number > 256 ??
