Using two amp sims in insert loop
alshaw80
Hi, I apologise if this has been covered in another thread, but I am wanting to try to run two amp sims in my insert loop. I was hoping to be able to able to do a split mono out to feed each amp sim and then use a lehle parallel switcher to reverse the phase of one of the amp sims and combine it to a stereo signal to be fed back in to the insert loop, is this possible?
If you want one amp sim on each side of the stereo signal, it'll work, but you need to keep the loop in stereo. Split Mono would put the try amp sims in series.
Thank you. Being fairly new to the PbC6x I didn’t quite understand the difference between split mono and stereo. I managed to get it to work with the stereo send amd return. I am astounded with the flexibility of the pbc6x. Thank you so much!
