They can share one MIDI channel. If you're likely to want to use the IA switches to turn on and off loops on the fly, you'd want to set the 2nd one to use a different range of IA numbers (this is clearly detailed in the manual and is very straightforward). If you're just using program changes and programming the loops on the Effect Gizmos themselves, you don't need to worry about this.
