Ventris setup
Boomusic
I just recently removed my Big Sky and replaced it with the Source audio Ventris. I’m very much a newbie at all things midi.
what are the basic settings for the Ventris? Such as the Pc offset, max pc, bank type. And the cc number and on value for turning on or bypassing .
TIA
As long as you have a fairly recent version of the PBC firmware, the Ventris settings are in there, you can just select Manufacturer = Source Audio and Model = Ventris in the Devices tab (or Edit Devices screen)
Oh ok. So
What about the on and off values? Like for Strymon it’s 102-0 for bypass and 102-127 for on
Most MIDI devices are 0 for off and 127 for on. Unfortunately, bypass is a bit problematic. Some manufacturers think that "bypass on" means the pedal is bypassed. Others think that "bypass on" means that the pedal is active. The pedal manual may have this information (although surprisingly, some don't). Otherwise, you can just try it and reverse the values if needed.
