Sorry to resurrect this thread, but just want to confirm there's no other option/approach I could take.
I have a PBC6x, a lehle mono volume S and a dunlop volume X mini. I want to have a volume pedal and an expression pedal on my board.
1) First question that serves as the foundation for the rest. Am I correct in understanding that if I put a volume pedal into a loop in the PBC6x (let's say loop 4 for example, i.e. after my 3 duzz/drives), it will function as a volume pedal would normally in the chain when the loop 4 is engaged, and the volume pedal would cease function/use when loop 4 is turned off/removed from the chain?
2) To save space, is there anyway to set it up so I could have one volume pedal function as EITHER a volume pedal or a expression pedal depending on the preset? If so, how would I wire/accomplish that?
This is how I think it would work, please let me know if my thinking is correct: I could wire the pedal for volume and place it in a loop, and disengage that loop whenever I don't want it to be functioning as a volume pedal, and then I'd separately separately have a (a TRS out from Aux send on the Dunlop Volume X Mini) OR the USB-C to USB-B of the PBC6x [or does it have to go to the expression in via a USB-C to TRS cable?]) the same pedal be used for expression over midi to my various pedals (strymons, etc.) on presets when desired.
Will this work?
And is there way I can do it without 'sacrificing' the insert loop to the volume pedal only? I'm not seeing a way.
I saw these as a way to add more loops if I need, not sure if they'll do the job:
As one of the leading innovators in pedalboard technology, One Control continues to listen to the working studio and performance professionals like guitarist Josh Smith. The One Control SSL unit was created by his request for a MIDI controlled stereo loop pedal to help tame his rig. Let’s let...
one-control.com
Remote control switching for your pedalboard or offstage gear. Have you ever wondered how to get your modulation and delay effects in your amp's loop WITHOUT those massive tone-sucking cable runs? Do you want your effects back at the amp, but have the ability to switch them with a simple...
shop.thegigrig.com
Alternatively I could add the RJM Mini Effects Gizmo, though that seems a bit overkill for me in terms of number of loops.
www.rjmmusic.com
3) (reasking the question buried above). Will the USB-C out on the Lehle Volume S send midi expression to the PBC-6x if I connect it to the PBC's USB In via a USB-C to USB-B cable? Or will a USB-C to TRS cord work if I plug it into the PBC's expression in?
Thanks as always. I'm continually amazed how responsive RJM is to questions like this.
