Volume Pedal
Discussion in 'PBC General Discussion' started by Devin B, May 7, 2020.
  1. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    I am trying to go out of “Out 5-6” —> Ernie Ball VP Jr. In —> Ernie Ball VP Jr. Out —> “In 7-10.”
    But I lose all audio completely! What am I doing wrong?
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,288
    1,121
    Make sure the "Mono->Stereo (Out)" button is set correctly. It should be out if you're using stereo pedals in loops 7-10, or in if you're using mono pedals.
  3. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    It is in the out position, but still no audio coming out of “out 5-6.”
  4. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    I am running in stereo. Boss DD500 and Strymon Big Sky are stereo in channels 9-10. 7-8 are mono pedals.
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    6,288
    1,121
    Are any of loops 7-10 turned on at the time? Does it make a difference if they are?
  6. JimB
    JimB
    Mar 4, 2019
    20
    1
    So you're going from mono loops 1-6 to stereo insert back to mono for loops 7 and 8?
  7. boyce89976
    boyce89976
    Mar 5, 2015
    343
    24
    Try connecting "out 5-6" directly to "in 7-10" without the EB VP JR. Do you have signal that way? If not, push the "Mono->Stereo (Out)" button *in* (since loops 7 and 8 are mono pedals). If still no signal, you may need to work backwards from "out 5-6" to see if your wiring is all good in loops 1-5 (you should be able to do that by bypassing every loop and turning one on at a time.
  8. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    No, it doesn’t make a difference. Still no audio.
  9. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    Attempting to run loops 1-8 in mono and 9-10 in stereo. Now see the problem with that, and when 7-8 are activated, they’re only coming out of the Left amp.
    It I switch to TRS cable for those two pedals, will that correct the problem? Both are Chase Bliss pedals.
  10. Devin B
    Devin B
    Apr 29, 2020
    7
    0
    Yes, if I run the same cable straight through, there is audio passing through. It’s only when I plug in the volume pedal. I have swapped out several volume pedals to make sure that wasn’t the problem.
  11. boyce89976
    boyce89976
    Mar 5, 2015
    343
    24
    You need to read the stereo sticky at the top. There are special cable you need to run the mono pedals in loops 7 & 8.
Share This Page
