SeanTorresMusic
I'm trying to edit my presets on the Walrus Audio Mako M1 and use the PBC6 to recall these presets. So far I have saved two presets on the pedal that I like on PC 0 and PC1. I've tried setting up a preset on my PBC6 that will recall PC 0, and a different preset that recalls PC 1. For some reason the pedal just stays on PC 0 even when I switch to PC 1, but I think it is technically receiving the midi because I can here a slight break in the signal every time I attempt switch between the two presets. I've attached my settings below and the two presets I'm using to test this pedal are Preset 3 "Comp/Chor" and "Tremolo".
