Wampler Terraform Expression pedal setup
Discussion in 'PBC General Discussion' started by Jhansenku, Mar 13, 2020.
  1. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    Still learning the PBC 6x. I’m trying to figure out how to set up my expression pedal through the editor to use with the terraform? I have the terraform selected as the device but get lost when I’m trying to assign the cc number? Anyone using the terraform with the RJM? I also have the collider, but just using presets in it.
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    I just had a look at the Terraform manual, and there's no mention of expression pedal control over MIDI. I recommend asking Wampler if there is a CC number that will act as an expression pedal.
    Jhansenku likes this.
  3. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    I have an email in to Wampler.
  4. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    I heard back from Wampler, no cc number. So I’m just going to use my expression with my Collider. Can you help me set that up? I’d like it to control delay mix.
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    In globals, double click ExpPdl 1 under Expression Pedals. In the window that pops up, set Device to Collider (or Nemesis, if you followed my instructions in my other post, set CC Number to 100. Then, follow expression pedal instructions in the Collider manual.
  6. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    100 is not available choice? CC has a drop down menu. There are selections but not 100? Do you have to do anything on the position switch action?
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    Just type in 100 manually. The Nemesis doesn't have a general expression pedal CC, but the Collider does.
  8. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    So what parameter will it control?
  9. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    You should be able to select which parameter the pedal controls using the pedal's editor app, maybe also on the pedal itself. Have a look at the expression pedal section of the Collider manual.
Share This Page
