shoelesscraig
Hey dudes,
Been using the PBC for a while now and I love it. Ran into an issue that I can't fix though...figured I'd throw it your way. I've attached my file in case someone wants to look into it firsthand (Ron maybe)...
On my main page (page 1) I have the bottom right button set up as a tap tempo if you just tap on it. Works fine going to my Timeline which is in loop 9.
Every preset may not have the delay loop 9 turned on, so I programmed this button so that if you hold it down, it will engage loop 9 (and also send my Timeline to a certain preset). The thing is...it doesn't always work that way. If I change presets and that new preset does NOT have loop 9 already on, pressing and holding this button will sometimes turn it on like its supposed to, but sometimes I have to press/hold, release, and then press/hold again for it to work.
Again, sometimes it works the first time, sometimes I have to do it twice...why would this be?
The changing the preset on my Timeline part works fine, and the actual tapping the tempo in works fine...its just the "engaging" of loop 9 that seems to not always work the first time....??
