Would this have any affect on the interactions with HX stomp FX loop? I put the PBc6X in the loop of HX, so I can maneuver it around the blocks within the HX. Today I set the effects loop jacks to line level. I did that because two of preamps in the loops of the rjm have high output to preamp‘s that will clip the FX loop. It doesnt clip when set to line level. The FX when set at line are 10Kohm. The reason I ask is because when I engaged my RAT pedal in another rjm loop... it had a spittier and gated sound. Like the low end was really flubbing out. When I took rjm out of the equation and just out the oreamps and RAT in JUST the HX FX loop set the same to line level... all sounded normal. What could be the issue? Ive been futzin with it for a while. Thanks
