Piplodocus
Mastermind LT in the post! Yay!
I probably should have asked all this first, but it was an ebay auction that was ending early in the morning. So I read as much as I could, had a quick fiddle with the editor SW, figured it should work, then put in a bid. I don't think they pop up *that* often here in the UK, and it seems about as good as it gets for what I want in a small package. Anyway...
So here's the plan, you tell me if it'll work, if it's simple, what bits may be tricky/might not work, or if any of it needs a re-think and/or I've misunderstood the concepts (happily using the Mac/PC editor for any of this deemed too advanced for the menu system)...
Did some buttons also have press-and-hold second functions or something? Maybe that's a question for another day, or it will all become apparent later when I have it in my hands...
Since I'm new here (although I thought I previously had an account for my other RJM bits!), a bit of background (if you remotely care): I'm currently trying to downsize my board as it's too large and heavy for most of what I do a lot of the time. My great behemoth does so much cool stuff I'm definitely not breaking it up, I'm making a new separate smaller board for the more stripped down rock n roll gigs with the LT on. The big board uses a pair of Liquid Foot Jr+'s (so I'm familiar with complex midi controllers), and I've got a pair of Amp Gizmos and a Mini Effects gizmo on the other board, so I'm familiar with RJM stuff in general, but not the Mastermind series directly; hence all the questions. My Strymon Timeline/Bigsky live in a mini rack on top of the amp along with the amp gizmo (short FX loop cables+MIDI controlled). This means the board out front can happily be changed from the all-singing-all-dancing loop switching/lots of pedals/epic controllers beast, to just the old phantom powered Voodoo Labs original ground control, with the amp/timeline/bigsky common to either set-up. The big board is often a bit OTT, and the Voodoo GC too basic. Enter the Mastermind LT!!! This should give me most of what I get from the LF+'s (in conjunction with with SmartClock), in an even smaller format than the GC.
Anyway, thanks for any info or tips. You probably deserve a drink after reading all that!
- I can make a whole variety of presets, each recalling different MIDI presets on my devices. This'll largely be just PC changes. (I presume this is a given!)?
- A preset change can also send multiple CC toggle messages if required (e.g. to switch pedal loops in/out)?
- I can make each preset set the expression pedal to a different CC on any different MIDI channel I like, or none at all? (My expression is often unassigned so I don't knock it accidentally, but may do delay mix to Timeline on a specific preset, or BigSky verb size on another, etc)
- I can use songs to set different presets in any order I like (and obviously re-use some presets across multiple songs)? So effectively presets exist "in the ether" with no particular button number, and patch buttons are placeholders for presets. It's the songs preset list that actually maps the presets to the buttons?
- I can set up setlists of songs. And I can easily choose a different setlist or edit a setlist from the LT menu?
- I can use bank up/dn to go up/dn songs of the current setlist?
- I can edit the page (button) layout using the Mac/PC editor. I can also enable/disable pages, so I can choose the page layout of each page and use the function button to cycle round the enabled pages?
- I can set up page 1 to have the first presets 1-4 of the song on buttons 1-4 (and have song up/dn on the bank up/dn buttons)?
- I can set up page 2 with the next 4 presets (5-8) of the song(I often need up to 8 presets a song).
- Presuming I only have these 2 pages enabled, Function will cycle between page 1 and 2 (so all 8 presets of the song are either right there in front of me, else only a function-press away)?
- Presuming yes, the bank up/dn on page 2 can instead then be 2 IA slots to toggle a couple of things on/off on something or set say tap division on the Timeline, etc?
- Can I easily tell which of these 2 pages I'm in (and what song I'm in simultaneously)?
- It sends MIDI clock? Can I make say the function button flash the current tempo?
- Setting the first patch of a song can set a new MIDI clock speed?
- I can use one of the external jacks as a global tap tempo and is pretty accurate (one of the downfalls of my liquid foot is it seems to quantise taps to discrete values so sometimes is nigh on impossible to get tap tempo quite right - hence my big board having a Disaster Area Smartclock)?
- If I use said tap tempo button to tweak the song tempo live, none of the other presets will change the midi clock, unless I change song, which then sets the new default MIDI clock tempo for the new song?
- When changing song or using the tap tempo, the external jack can "tap" the external tap input of one of my modded Subdecay Prometheus DLX so my step filter is in time with the Timeline repeats (like my SmartClock pedal currently does). And I can set the number of taps it sends correct (e.g. 4 taps), as it doesn't like being continually tapped?
- Can the IA slots dynamically shift per preset? E.g. If my page 2 has bank up/dn as a pair of IA slots (as per point 7, can on preset 1 the first IA toggle a drive on/off and the second an amp boost, but if on preset 2 they change to being a fuzz on/off and delay infinite sustain say. (What a Liquid foot would call IA maps)
- Anyone had any luck controlling one of the old original Voodoo Lab Pedal Switchers? The new ones like my PX-8 just directly have CC assignments. But the old ones you have to send a sysex string which makes it configure itself to the first 4 CCs (which it then in turn sends out another sysex string which configures any other pedal switcher downstream in the midi chain to be the next 4 CCs). I note in the editor there appears to be a boot macro setting, and macros can send sysex, but when I've tried this previously if the sysex is sent too soon the pedal switcher isn't ready and doesn't get configured. Not a deal breaker by any stretch, but I have one of them about spare, and adding a 4-loop switcher with dedicated manual buttons to use on the fly, but switchable with LT presets would be pretty ideal.
