Write Button not flashing
Paulg2uk
Hi all,
Slight problem with my amp gizmo. I've recently swapped from the nova system to the g system. I have set both the g sys and the amp gizmo to midi channel 1 but the write button isn't doing anything.
Is there something I'm missing? or do I have to reset the amp gizmo?
Any help would be great
Many Thanks
Paul
Sounds like the Amp Gizmo isn't receiving MIDI Program Change info. Is this something you have to enable in the G System?
I'm not too sure. It might be cause the amp gizmo is set to the same midi channel at the g system. It might be worth a post on the TC fourm
When we had a G-System in here, we got it working with minimum hassle, so it's probably something minor.
I believe there's a setting in the G-System to enable transmitting program changes. Have a look at that and see how it's set. Check the MIDI cable, too!
Thanks guys I managed to sort it out. I basically just unplugged everything and started again. I think it might have been a loose connection. All working now though lol.
