Time to revive the thread
First I should say hello: hello, my name is Tom and I am RJM distributor in Poland.
Let's get to the point: I've got three "never to sell" amps. To give you a full picture I would have to write few things about Tom. Tom is probably the most awesome amp guru in Poland and one of the best in this part of Europe. The only problem is that amps are "just" Tom's hobby, so it is extremely difficult to get him do some work on your amp, even tougher to get an amp built by him. Luckily he is my friend
1. Hellstone Prodigy
Hellstones are handbuilt by Tom. There were only three Prodigies built and it was extremely hard to get one. This is the most complex amp Tom has ever made and it is completely hand-built by him, including transformer winding. One could say that it is a Dual Rectifier clone to some extent, but it is more accurate to say that full DR is included in it's featureset
, since you can make it sound like a Recto, but this is only one of it's many sides. Here are some tech details:
Preamp using 6N2P-EW tubes, which are military soviet versions of 12AX7 (there is a switch for each tube socket so I can replace them with 12AX7 if I want to), power amp using 6P3S-E tubes, which are USSR military versions of 6L6GC and are the longest lasting and best sounding 6L6 versions I've ever used (including Groove Tubes, JJ, Sovtek and others) - cool thing is that you can still buy them NOS here (for 8-10 $ per power amp tube and 2-3$ for preamp tube!
. Three channels - Heaven/Clean, Earth/Rhythm Hi Gain, Hell/Lead Hi Gain, all with separate Presence, Master, Bass, Treble, Mid and Gain. Clean channel has Plexi/Tweed mode switch and Vintage/Modern mode switch. Both hi gain channels have Crunch/Lead modes (which changes gain) and Classic/Modern switch - classic means Recto, Modern is the real Hellstone
- no other amp sounds like that, so it is quite hard to describe. Great sustain, warm sounding and filtered in specific way that cuts great through the mix and is incredible in recordings. There are also four switches that dramatically change hi gain channels voicing - Freak, which moves some filter frequencies (for two completely different sounds), harmonics on/off (that enhances high end), Low EQ I/II that moves lower frequencies boost and Mid/Low boost
. That's not all - there is also plenty of switches on back panel, including Triode/Pentode mode (which changes power and sound in range of 60W/120W), Channel mode (works the same like channel cloning on rectos - so you can either have vintage/modern, modern/modern, vintage/vintage), Headroom Low/High, Deep On/Off
. There is also a effects loop assign rotary selector, two masters and slave output. Many functions can be controlled by footswitch (and Mini Amp Gizmo/Amp Gizmo does great job with that).
This amp is an all tube Pod - there are endless combinations, for example you could use Plexi/Modern mode on clean channel, crank up the gain, switch headroom to low and voila - EVH-type sound
. Change to tweed mode, put something like BB Preamp or tubescreamer in front and you get Andy Timmons kind of sound etc. The only thing that this amp is not capable of is a very cleanish bright clean. No worry, I've got another amp for that:
2. Hughes and Kettner Triamp MK1
This amp was extraordinary when I bought it, but got even better after some hotrodding (made by Tom from Hellstone
. Another all in one amp, 6 channels, built in midi interface, sounds covering bright cleanish clean, thicker not so clean clean
, two marshall style crunch/overdrive channels, two great higain channels. I also went on tubehunt for this amp, found 4 NOS Teslas e83cc with goldpins and used them for Marshally channels, and RFT ECC83 for the rest.
3. Extremely hot rodded Ashdown Fallen Angel 180
This one was an experiment. I hated this amp's original sound, but it had some nice and unique features - so during 2:00 am skype conversation with Tom, I asked him if he would like to experiment with it and he agreed. I bought it for a very good price when I was working for Ashdown distributor and it was the last one they had (they were discontinued). Tom changed it a lot and changed overdriven channel to an awesome Bogner Uberschall meets Mesa higain - it is extremely tight and distortion is very similar to Bogner Uberschall, but tonewise it is different, with richer mid content. It also received presence control, and a switch that adds a cap somewhere, that changes lows from tight to tighter
. What's really cool is that gain control changes tone a lot (gain enhances harmonic content), but even at max settings it is still tight, clear and reacts great to playing dynamics. This amp works great with 7 and 8 string guitars too. Add to this some if it's original features:
6x EL34 for great headroom and lows
2 effect loops assignable to channels
Gain boost on channel 2
Huge transformers
Looks nice
