on the editor choose transfer\write settings to device..then test on pbc.
may sound like a dumb question...are you writing settings to device and testing on the pbc?
Yes
That pg 4 then should be sending those midi cc...if the pedal is not responding to them is there a mode or setting in the pedal that can be adjusted...can the pedal mode be incorrect
I dont believe so. I've spent the past hour pouring through all the settings and re-reading the manual. Its set to normal mode, which treats A and B effect independently. It's set to receive CC messages, the Midi channel is fine and the PC's get through with no issue.
copied from DD-500
In the DD-500 there is also a MIDI MENU for MIDI CC#.
(Press [EDIT] and [ARROW UP/DWN] button to MIDI and press [EDIT/ENTER] to view).
Once in the MIDI MENU. [ARROW UP/DWN] button to:
EFFECT SW: CC#27
EFFECT A: CC#28
EFFECT B: CC#29
These are the CC# assignments for EFFECT SWITCH, EFFECT A and B.
are these set or there?
ecognized if “Assign: SRC” setting is “CC#1- #31, CC#64 - #95. do you see that parameter
I'm not the expert here by any stretch...but I just want to point out. I came across a forum on The Gear Page (I think it was) where they are discussing the Boss pedals and they DID note that the DD500 is different than the RV and MD as far as how bypassing works. I suppose one of them is older (maybe the DD) and the others had differences in them that they expected Boss to update via firmware at some point. Not sure if they ever did or if you've updated yours or not.
I say all that to say, based on that thread I read (can't believe everything you read on the internet) it wouldn't surprise me for them to act different than one another. I know that they logically shouldn't...but I think they do. THAT is why in my file I had the OFF button sending a 127 and then a 0 to CC27. The poster in the thread said it had to go up and then back down to bypass. Maybe he's crazy, but that's why I did that...just so you know.
Rx CHANNEL is 4
CC IN is on
are those set?
also...how is midi cables set....for now come out of pbc directly in md500...don't daisy chain as the pedals need set for this. if they are not configured correctly, they may not pass cc messages...lets keep things simple check your pm
