Here's the final 4.1.0 release for the Mastermind GT. Many thanks to all the beta testers!
FEATURES
- First, back up your settings to a flash drive or computer! If you go back to 4.0 or earlier, your GT will factory reset.
- Power on the Mastermind GT while holding the 1 and 3 buttons.
Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT410.zip
Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.1.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.1.0.zip
Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.1.pdf
Here's a video I did for the 2nd beta test, this still applies to the final release:
FEATURES
- Axe-Fx III support!!! Support for presets, scenes, effect channels, tap tempo and tuner, using bidirectional communication. Requires Axe-Fx III firmware 1.15 or higher.
- Added more options to Get Preset Names to allow reading of both preset and scene names from the Axe-Fx III
- Added Show Scene Names option - displays current scene in the lower row of the main display
- Added Scene Menu button type
- Added Get Preset Names button type
- New button options for hold functions: "IA Mode Only" makes the hold function only work when IA mode is active. It will also only be displayed when IA Mode is active. "Show Name" allows to you turn on or off the display of the hold function's name in the button display.
- Support for volume pedals (log taper correction)
- Added support for Ramble FX Kismet pedal
- Added Strymon Riverside and Sunset support
- Editor now has "Show Tool Tips" option so you can turn them off when they start annoying you
- Fixed CC definitions for Empress Echosystem
- Fixed external switches to allow them to be preset buttons
- Fixed a number of bugs with Copy Buttons and Swap Buttons on hardware
- Fixed editing of Hold mSec on GT
- Added missing IA Cycle Menu option in GT menu
- Brought back missing Sysex action type in editor
