Here's a new release for the GT. This one fine tunes Axe-Fx 3 support and fixes the broken Axe-Fx 1/2 support.
SPECIAL AXE-FX III NOTES
FEATURES
- First, back up your settings to a flash drive or computer! If you go back to 4.1 or earlier, your GT will factory reset.
Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT423.zip
Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.2.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.2.0.zip
Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.2.pdf
- Works best with Axe-Fx 1.18 beta or later
- The recommended device settings when working with an Axe-Fx III are now:
- Direct Send: OFF
- Send Redundant PC: OFF
- Poll State: ON
- Ignore Incoming CC / Ignore Incoming PC: OFF
These are now the defaults when setting up a new GT. These should give the best results in most cases, although certain special cases will require different settings.
- In order to see the Poll State option in the Devices tab, you may need to set your device to a different type, like "Axe-Fx II", then set it back to "Axe-Fx III". You should only have to do this once.
FEATURES
- "Poll State" setting for the Axe-Fx III makes the GT query the Axe-Fx's state periodically so that any changes in the Axe-Fx or Axe-Edit will show up on the GT. This will work for effect block bypass and channels. If you also have "Ignore Incoming PC" turned off, it will also track preset and scene changes from the Axe-Fx and Axe-Edit.
- Fixed broken Axe-Fx I and II support
- Fixed Remote Mode when using an Axe-Fx III
- Fixed double flashes when Calc Tempo From Flashes is active
- Allow non-Cycle buttons to properly sync with effect block channels
- Fixed problem with IA Cycle buttons
- Fixed issue with controlling the higher numbered Axe-Fx III effect blocks.
- Fixed scene handing when "Direct Send' is turned off
- Allow scene buttons to sync when Poll State is on and Ignore Incoming PC is on
- Fixed a bug that caused problems with non-CC IA buttons
- Fixed problem with Scene Menu when Direct Send PC/CC is turned off
- Fixed a bug that caused synchronization problems with Axe-Fx III channel selection and IA Cycle buttons
- Fixed a bug that caused incoming PCs and remote mode to occasionally select the wrong preset.
- If your GT presets are selecting both presets and scenes on the Axe-Fx (such as when using Get Preset Names / Create Songs), you will see it switch to scene 1, then to the desired scene every time you move to a new Axe-Fx preset. This is something I'm trying to work on with Fractal.
