Hi Ron,
i've just upgrade the last firmware, since the display is not backlit ??
I've came back to 4.06 and the display didn't work anymore..
I beta tested 4.07 and had zero FW related issues.Hi Ron,
This, unfortunately, sounds like an issue with your PBC and not a firmware issue.
It is weird, cause when i power the PBC, the Backlit work and just after presets are loaded it switch off but i always can see the preset name or IA etc...
Hey Ron, in the editor, I can no longer scroll through the songs in the left window of the setlist tab using the arrow keys on my keyboard? Same thing on the left window of the songs tab?
Wow, that is strange. Can you send me your settings file so I can see if I can reproduce the problem here?
Hi Ron,
Some news?
I can use the PBC but my eyes are not so goods than ten years ago....
Absolutely, everything works great but not the backlitI don't have the same problem here when I load your settings, it must be specific to your PBC. Do the LEDs over each button work correctly?
Hi Ron,Version 4.0.8 now available - this fixes tempo issues in prior releases.
Hi Ron,
i've just loaded the new firmware, during transfer the Backlit works normally, and when it finishes, it stops working.
just before it stops, i can hear a relay , could it be it??
All of PBC works normally...
As I said before there must be something wrong in the hardware, a short somewhere perhaps. Otherwise, I would have seen the same problem when I loaded your settings here.
Please contact me at support@rjmmusic.com and we can figure out how best to help you.it's very weird because when i power on the PBC, backlit is lighting normally and it turns off 2 seconds after...And however is working perfectly..
so what can we do now with this issue?
