Transfers settings vs changes
Ok, but let's tackle one problem at a time. If you change the EQ's channel number to 3 in the Devices page, the Ventris should start working correctly. Can you confirm that?
I assume you are referring to changing it in devices page in the Editor. My understanding is the change only takes affect after transferring changes from the editor to the PBC?
OK. I will literally take this one step at a time. I followed your instructions. I switched presets on the PBC 1- 12. The Ventris preset did not change. It stayed on Ventris Preset 2. Would like to know why it is on P2. I am not going to touch anything at this juncture.
I defer to you for the next instruction and / or question.
For reference, this what the EQ presets looked like when I switched PBC presets -
PBC/EQ: 1/2, 2/2, 3/2, 4/2, 5/1, 6/1, 7/2, 8/2, 9/3, 10/4, 11/5, 12/6, 13/1, 14/2, 15/3, 16/4, 17/5, 18/6, 19/1, 20/2, 21/3, 22/4, 23/5, 24/6
Hello,
This is in reference to our latest correspondence and the attached setting file you requested.
This i what the Source Audio EQ2 presets looked like when I switched PBC presets -
PBC/EQ2: 1/2, 2/2, 3/2, 4/2, 5/1, 6/1, 7/2, 8/2, 9/3, 10/4, 11/5, 12/6, 13/1, 14/2, 15/3, 16/4, 17/5, 18/6, 19/1, 20/2, 21/3, 22/4, 23/5, 24/6
Steve
  • Steve's Settings Nov 20 2305.rjs
I had a look at the Presets tab, and that's exactly what the EQ2 is programmed to do. It's off by 1, but otherwise, it's correct:
Using your notation, you have it programmed like this:
PBC/EQ2: 1/1, 2/1, 3/1, 4/1, 5/0, 6/0, 7/1, 8/1, 9/2, 10/3, 11/4, 12/5, etc.
You can fix the off by 1 error by going to the Devices tab, setting PC Offset to 1. You will probably need to go through each preset in the PBC and subtract 1 from each PC sent to the EQ.
In the Devices tab I changed PC Offset to 1. Should I save this as a new file and "Write Settings to the Device"?
Then should I go through each preset in the PBC and subtract 1 from each PC sent to the EQ?
I recommend changing the PCs, then wiritng settings to the device (and saving the setting to you computer as well).
What are the steps to go through each preset in the PBC and subtract 1 from each PC sent to the EQ2?
There is where I’m at thus far:
1. Go the setup menu in the PBC
2. Go to Edit Presets
3. Edit Preset 1 (to begin).
4. Scroll down to the device = “Prog EQ” (there is a “1” to the far right of the display)
5. Selected Prog EQ
6. Now it shows Edit PC Message
7. I changed it from 1 to 0
Did I follow the procedure correctly?
The PC message is set to “0” on Presets 5&6 already. Do I leave those alone?
what about Presets 9/2, 10/3, 11/4, 12/5? Do I subtract “1” from these? Which then would look like this = 9/1, 10/2, 11/3, 12/4?
if so, what is this accomplishing?
Somehow I just did something on the PBC that affected Page 1 (Presets)
Now the display shows
Preset 1
Preset 1
But none of the switch LEDs are on.
When I press the Function switch it cycles through the pages normally - it goes to Loops (preset 1), loop7 (preset 1) then Switches (preset 1) and then back to the first page Preset 1 (Preset 1 ).
What did I do and how to I fix it? Ugh!
When I go to system menu and press Esit Buttons, it shows Select a Page and Page #1 is blank. Page numbers 2, 3, & 4 are identified correctly as Loops, Loops 7 & Switches.
When I select Page 1 it goes to “Edit Page 1”. The two options are “Name” and “Type”. To the far right of Type is Preset. I assumed that’s would Page 1 should show.
I scrolled down and selected Type / Preset.
So I shut down the PBC for 3 minutes and turned it back on. Now the display shows Song1
Preset 1
and still none of the LEDs are on
