Hi. I've made some fixes and have a question:
I was having problems with the "Blank Preset" on the Volante...so I did a Factory Reset on it and started from scratch.
I found a way to bypass the unit from any individual presets:
PC Actions: Click off Volante
Preset Actions: CC Toggle #102 (Bypass)
What was interesting with this is that I wasn't able to just type in the Toggle #102 for subsequent Presets. Always had to choose it from "Select CC". Otherwise it didn't work. But the happy ending is that it DOES work when set up this way.
I also figured out Trails.
Preset Actions: CC Toggle #83 (Persist).
At first I didn't think it was working when I'd switch between presets...but then I remembered that you have to wait a few seconds when switching presets for it to engage. Not like you're switching back and forth in a hurry while you're playing an actual song.
Problem I'm having now has to do with assigning new Volante presets to the Mastermind presets.
I think that my disconnect is with the term "Send a MIDI Change message" from the MM to the Volante. I don't know how to do this. As is; these are the steps I take, using the screen on the physical device:
1) Click on Edit a Preset
2) Click on the Preset Name/Number I want
3) Click on “Volante”
4) Set the new preset number on the Mastermind Screen
5) Set up the new sound on the Volante
6) Press the Favorite button on the Volante until it blinks blue.
After that, I’m not sure how to proceed. I've set up a simple lead delay as #9 through what I can only call "luck". Don't remember what I did to save the preset after the Favorite button blinked blue...but it's done.
Where i've run into trouble, now, is when I try setting up a dotted 8th preset. I'll dial it in just right, set the board preset I want to #10, press the Favorite button, and then exit the edit screen. The MM preset sounds great until I move on to another and then back to that one. All of a sudden, the Repeats on the Volante are WAY too many. I've tried to redo the preset but always end up with the same problem. And whenever I'm in that Edit mode; the original Preset #10 sounds great. It's when I exit and move away from and then back to the effected preset that the Repeats become a problem.
I contacted Strymon. They're trying to be helpful but suggested I clarify: how do I Send a MIDI Change message from the MM to the Volante, after setting up a new Volante preset? I can't seem to find it in the manual.
Like I said: I had success with a simple lead delay as #9. I was thinking it might have to do with an Expression pedal that I no longer use...though that was set to control "Mix" only.
