ZappaFrank
I have read the following info about the FS-7:
The Boss FS-7 is a compact, dual footswitch. It will work with our products if you follow these guidelines:
Use a 1/4-inch TRS cable to connect the external switch jack to the B jack on the FS-7
Set the Polarity switch to II
Set the Mode switch to Momentary
The FS-7 must be powered in order for the Polarity and Mode switches to work properly! This is an odd "feature" of the FS-7. It can be powered by a Boss PSA or 9 volt Pedal Power output. The FS-7 has LEDs, but they will only light when the button is being held - the LEDs will not be able to be controlled by the GT or PBC like RJM external switches can.
So when I follow these guidelines can I use the FS-7 with the PBC6 and/or PBC10 (because I have both)?
Will it then work as a single or as a dual switch? Are there any tutorials about this?
