lbcbdr
I recently discovered that if i turn buffer 2 off i get no audio. Normally I have all 3 buffers on but loaded a config the other day that had a preset saved with the three buffers off the a and b outputs off and the dry signal off, so, I started turning things back on starting with the a and b outs then the dry signal, and finally the buffers that's where i discovered that buffer 2 was not passing audio when off. It doesn't matter the state of the other buffers. I have a volume pedal between loops 6 and 7 and loop 7 is serial, 8 & 9 are parallel and 10 is serial. Any ideas?
Thanks LBC
Thanks LBC
